Groton PD on CSERN ... But Not Troop E As CSERN Doesn't Work In Troop E Yet?
cg
Connecticut
#61
I don't know if the buses are on the P25 system all the time yet. You could be monitoring both parts of the system. If the scanner gives you frequencies in addition to the talkgroup IDs, look at that. For Troop E, 700=P25, 800=Motorola 4.1
chris
thom
Connecticut shore
#63
[QUbus with a tag of 4062 was on the troop E OTE="cg, post: 3122371, member: 25"]I don't know if the buses are on the P25 system all the time yet. You could be monitoring both parts of seat the system. If the scanner gives you frequencies in addition to the talkgroup IDs, look at that. For Troop E, 700=P25, 800=Motorola 4.1
chris[/QUOTE]
Seat Bus with a tag of 4062 was on the Troop E system this afternoon. The freq. was 771.6562. As I've said, unlike the troop, I get the Seat buses without my roof antenna. I don't know why I can't get Troop E or Groton Town Pd without the roof antenna.
cg
Connecticut
#64
Same frequencies, same repeaters, very strange. It is possible that the different brands of radios or different people programming the radios have settings that cause issues with the inexpensive radios (scanners), but that is speculation.
Groton Town doesn't have it's own control channel. The control channels for Troop F's P25 is in the database. Colchester P25 site is a single site and not the simulcast yet.
chris
n1chu
Farmington, Connecticut
#66
Why would any Groton radio be affiliated with anything in Avon?
You can listen to any talkgroup in the system provided it’s simulcast. Apparently, Groton PD’s TG is simulcast off the Avon site. (The Avon site would cover Hartford.) This would allow for Groton to be able to talk back to their dispatch from anywhere in the state provided simulcast was turned on for that local’s site. I live in Farmington, next door to Avon. I should be able to hear Groton as long as it’s linked (simulcast) off the Avon site. I think the need to simulcast is there. Say for example Groton has a need to report to Hartford for court appearances, etc...
mkt853
CT
#67
Eventually they'll strap certain talk groups to only work on certain sites.
Southeastern CT
#68
Question, what is the I.D. for Groton Long Point? I known "GLP" is on the CSERN system because they told the Groton RTM they bought their own radios for their police and patterned it after the Town Police.
