Ground Plane Antenna
raski
Doing some attic cleaning and came across my Radio Shack ground plane base antenna. I believe the box states 0.64 wave. Is there any marketable value to this antenna? It is in very good condition and wasn't outside for very long.
Probably.
It's a 5/8th's wave antenna that would work pretty well. If the price was reasonable, you might get some interest. New base CB antennas can be had for less than $100 thanks to mass produced stuff out of China.
Getting $30-$40 for a used one in good shape might be possible if you found the right buyer. I wouldn't expect more than that.
Retroradio
Ontario
Radio Shack made a .64 wave antenna and they performed pretty well. I ran one for awhile back in the day but went back to my trusty 5/8th wave . If I could find one locally I would seriously consider picking it up as they were great antennas.
jonwienke
More Info Coming Soon!
VA
.64 IS a 5/8-wave...just a different label for the same thing.
Retroradio
Ontario
My experience in running both was that were different in performance.
The 5/8 was shorter than the .64 antenna.
The 5/8 had a top hat, the .64 did not.
The 5/8 had 3 groung radials. The .64 had 4.
The 5/8 had according to the catalouge 4 db gain. The .64 had accordingnto the catalouge 4.5 db gain.
So IMHO they are 2 different antennas.
Once again this was based on my experience and I referenced the catalouge to double check my memoey on them being different.
Check out page 84
1980 Radio Shack Catalog Pages 51 to 100
prcguy
A few years ago I bought a NIB Radio Shack 5/8 base antenna with 3 radials and a top hat off Epay in the $35 range and used it for about a year. It was an upgrade internally from the 1970s version which had a circuit board coil in the base and the one I got off Epay had a wire wound coil instead.
I recently bought a new style Hy-Gain Penetrator SPT500 to replace the Radio Shack and can tell it works better than the RS even thought they are both rated as 5/8 wave. The RS is 19ft 10" long to comply with old height rules and the Penetrator is over 22ft long. The extra height, no loading coil and the extra radial is probably responsible for the better performance.
prcguy
Check out page 84
jonwienke
VA
Meaningless. The loading coil, matching transformer, and "top hat" will all affect the physical length of the antenna, but that doesn't change the fact that they are both examples of 5/8-wave antenna designs electrically.
lmrtek
Since it will easily outperform a Antron 99, you should ask at least as much.
Retroradio
Ontario
As I stated based on my experience they worked differently. I preffered the 5/8 ant.
They may both be 5/8 designs electrically however they are 2 distinctly different antennas.
swen_out_west
Upper Mojave,CA/NV
It all depends on the market. Sell it locally if there are a few cb diehards around you. The shipping cost on Ebay might be cost prohibitive for a lot of potential buyers.
The point made above regarding the 500 or Sirio 5000 is also going to be a hurdle, most diehards already have a ground plane/quad or one of the aforementioned. However, with that said, if you were local I would buy it for $50 (if you brought it to my house and helped me set it up) just to try it out and have it as a backup.
prcguy
As I mentioned in a previous post I recently paid around $35 on Ebay for a new in box Radio Shack 5/8 base antenna. They can go for more and maybe I was luck nobody else was bidding that day.
And for swen, I would hold out until someone not only sells you the antenna and installes it, they better include a good radio for that $50.
prcguy
jim202
New Orleans region
They make fine antennas for use on both 10 meter FM and 6 meter FM use. They can be cut to operate on both bands.
Problem is the shipping cost make them a poor selection if you don't live within driving distance of a few hours.
raski
Thanks for responding. I will try to sell locally at the next hamfest in the area. Atleast I now know there is "some" value to it. I wondered if it were worthless and I would be using segments as tomato stakes.
prcguy
Ebay is the only place to sell something like that. Prices vary with the wind but nothing else will get the exposure like Ebay. People at hamfests don't like to spend much money. When their wallets come out you can see the dead moths falling out and that's usually all that comes out. Been there, done that.
Shipping is what it is but there might be someone across the country willing to pay more than you can imagine for your antenna. You will never know until you toss it out there.
prcguy
Retroradio
Ontario
Id buy. 5/8 or .64 if the price was right but the issue here is the dollar exchange rate if it comes from south of the border and the shipping costs make or break a good deal.
So local scroungeing it is.. An eaxample is have been looking for a 5/8 and a Super scanner for decades....nope. Up here Older CB antennas are hard to find.
Good luck with the antenna. Made for some interesting online dialouge anyway. :)
Rred
I'd disagree on ebay. Shipping has gone ridiculous, even on a direct UPS or other account. Cross country can easily be $10 per pound, and that's before they penalize it for being "dimensional", i.e. longer than a normal box. Craigslist, hamfest...nothing is perfect but properly boxed up and insured to post on ebay? I think that's going to hurt.
Doing the math, 5/8 is actually 0.625 around here. So it isn't a .64 wave antenna, but it is darn close, when you're using Arabic numbers for the measurement. FWIW.
