I can be more specific if it would help, but for a ground plane radial to be effective, how much clearance (from other objects) should these radials have on all sides?
For example if I mount an antenna as pictured below... these is some limited distance between the ground radial and the roof of my dwelling. Obviously it would be ideal if the antenna were located at the peak of the roof, but this is not possible. Is there a rule of thumb for how far away it should be otherwise?
