I'm sure this has been covered before but after searching for a while I couldn't find a specific answer.
I've read that you should ground the coax shield at the entry point to your home. For obvious safety reasons but also to help get rid of static charge from wind hitting the antenna.
What is the best way to make the connection to the coax shield? Will using a surge protector such as a Polyphaser connected to a ground wire/ground rod accomplish this?
Thanks!
Thanks!
