roth_ritter
If one grounds the antenna shielding (as in via a Polyphaser lightning arrestor) to a ground rod near the house feed point, is it redundant to ground the receiver as well? Is this basically the same thing?
-R
-R
i don't know about anyone else... but my practices are that i ground the antenna to 1 rod, and my rig to a totally separate ground rod at a different location. But that is just my method and seems to work fine for me.
What would be worse, an antenna that is not grounded properly and when storms are approaching you disconnect it, or install some sub standard grounding that will not protect anything but you treat it as if it will?
prcguy
Let me digress for a moment since my original topic has ballooned into something bigger...
I know that nothing is going to be a guarantee against a direct lightning strike. First I'm just looking for a little transient static discharge safety for the rigs. I just got a Polyphaser for this and it needs to send this charge somewhere. That somewhere is a close by 8' rod. The first task I have is to make sure that this is going to work or whether it will be a waste of time because of the ground rod not being bonded to the house mains.
Second is tackling an RF ground for the radio, but first thing is first.
