Grundy County change?
ed196312339
Morris,Illinois
About a month ago I stopped receiving Grundy Co. 911 shuffle band on my BCD996T. Does anyone know if there has been any changes?
RoninJoliet
ILL
They have turned off the "Shuffle" for now, u have to re-install it as a rebanded Motorola System using standard "tables'....
pto
Grundy Co. IL.
Just change the tables to custom/reband..
As Ron posted, re-install it as a rebanded Motorola System using standard "tables'.
The change will be temporary, as We are testing new radios that cannot do the Shuffle system.
The change will be in place for the next few months.
RoninJoliet
ILL
You must change the menu for Grundy to "Custom" from default then add the tables Plan1-2 depending on what scanner u are using...If its RS/GRE the tables are in the GRE forum, if Uniden there on the Uniden scanner site or Wiki on this web site.....
fullmoon
bourbonnais, illinois
Thanks for the help. I figured it out finally. For some reason it was confusing to me. Lol. Are they going back to the shuffled plan again in a few months??
