Gsr 300 info
rmiller818
Marietta GA
i am getting ready to buy a GSR 300 AND WOULD LIKE TO KNOW IF THEY ARE BEING SHIPPED WITH THE UPGRADE FOR REBANDED SYSTEMS?
The GRE PSR-300 is capable of receiving a rebanded analog trunk system. You will have to enter a custom trunking table to do so (best to use software)
mikey60
Oakland County Michigan
If it isn't, updating the firmware to the version that supports it isn't too difficult and is available from http://www.greamerica.com/support .
Also, if the system is rebanded, and any of the frequencies are between 851 and 854 MHz, and have a number 0 in the 4th decimal place (i.e. 851.02500), you'll need to use one of the programming software titles to enter the custom tables needed for that system.
Mike
