APX Guide to setting up Channel Announcement?
human8472
Does anyone have or know of a guide that goes over how to create voice files using TTS (Text To Speech) and then importing those voice files into CPS so they can be used? Something that would use really available software such as AUdacity would be great. I have an APX6000 as well as an XTS5000. Thank you.
EDIT: I think I found a YouTube tutorial that covers the process.
Outerdog
T¹ ÆS Ø
The Help files in both CPS has all the details. Thought it should be noted that the process is slightly different between Astro 25 CPS and APX CPS.
Hobbyscan
For APX: You can do it in Audacity. Save the TTS MP3 and import that in to Audacity. Change the sample rate to 8000Hz. Then export to another file folder as a WAV. Once all your files are built in your folder you can convert them through CPS as MVA's. You'll get it figured out by trial and error.
