UFOMAN
This request is specifically directed to those of you who live and scan in the Halifax Regional area of Nova Scotia.
I have had a GRE PSR-600C for about two years now. I bought the key for Win500 and downloaded the frequencies from RR and programmed the scanner myself. It works … and I suppose I should be satisfied.
That said, I don’t feel that I’m getting optimum performance out of the radio … and I believe it’s the way it’s set up. One of you know better, I’m positive.
Other posters have mentioned specific towers in the area … have they set up their scanners to only take signals from those specific towers? If so how is that accomplished?
I would like to have the radio set up like a cell phone … with a “roaming” ability, so that if I’m in the Truro area, the radio will find the tower putting out the best signals for the various talk groups digitally as well as any local analog signals that might be of potential interest.
Over the past thirty years, I’ve owned three other scanners ( still have them) and had a lot of fun using them. I picked the hobby up again a couple of years ago and discovered my old Radio Shack Pro-60 scanner was no longer any good for HRM police and fire and many of the other frequencies that are now on this trunked system.
So, I guess my question is: What’s the best way of setting this radio up to get the most out of it and with the best performance/signal strength? I live in Dartmouth … in an area sometimes referred to as the “Portland Valley” where, apparently, signal strength is compromised by the low elevation, Shearwater, and god knows what other (extraneous) signals that interfere with and degrade what the scanner picks up.
I would like to cover all the bases as far as the frequency spectrum goes … but I do not want to fill spaces with frequencies simply to have a lot of frequencies. That is pointless. On those occasions when I take the radio in the car and drive to the Annapolis Valley, Truro, South Shore or Eastern Shore, I would like to be set up to monitor area frequencies specific to those areas as well as RCMP, EHS and FIRE talk groups that would be active.
Should I set up V scanners for each of those areas? Or is this necessary … and, at what point would one switchover to the “new” area you’re moving through?
If you can help me get out of the woods that I seem to be in here, it would be greatly appreciated. Perhaps, you have this radio and also use Win500, if you could send me a XML file of your configuration I could use it as a template to re-set my scanner. There must be a better way than I ‘m presently using. I need your expertise and experience.
Thanks, in advance, for any and all input on this.
