Hand held radio
jaspence
Michigan
#5
Hand held radios
What range is needed? License free or licensed? Indoor use or outside? If inside, what kind of structure? All of these can change the answer.
jaspence
Michigan
#9
These are job site radios and are not on the MURS frequencies, they are on 900 Mhz. You can get a decent MURS radio for far less than the price for the DTR410 at Motorola RMM2050 MURS Two Way Radio. The metal building can be problematic on any low power output regardless of frequency.
