Yes Sheriff is so far still on the trunked NXDN. PD may also still be under a different frequency. Within the last week they’ve moved PDs. They’ve been talk of P25 System but that’s kinda hard to believe with SO and Fire still on NXDN TrunkedHave they changed from the trunking system?
I’ll throw it in and see if I can pick anything up on it! I appreciate it!Could it be this? It's emission designator appears to NXDN...
It shows as being active effective: 08/30/2023..
Edit: Here is the link, FCC Callsign WPDJ642 (HARLAN, CITY OF)
No problem . Let me know if you get anything, I am close enough to where I may be able to hear it, too.I’ll throw it in and see if I can pick anything up on it! I appreciate it!
So far I’ve had no luck. But considering what I’ve been told that they are the same system as Fire now which is conventional NXDN. Once they Freqs are found you should be able to pull from the pathfork repeaterNo problem . Let me know if you get anything, I am close enough to where I may be able to hear it, too.
Do you know where redbird is, in northern Bell County? Well, that's where I actually live. Pineville is just where I put my location as (nearest town). Hopefully, I can pick them up.So far I’ve had no luck. But considering what I’ve been told that they are the same system as Fire now which is conventional NXDN. Once they Freqs are found you should be able to pull from the pathfork repeater
Seems they've redone the system a little, heard from a source in the area that there's an active talkgroup (presumably sheriff) on TG 2001 that's encrypted. Not sure about the PDs. The Inman site now has three repeaters instead of four (453.3125, 453.56875 and 453.8125). Maybe the fourth repeater is being utilized for the police departments? Frequency would be 453.66875 most likely.
