Harris firmware
radiotech33
County line road
yep its old.. got all that fixed...good to go.. I appericate the information.. 1 question... if you brick a xg75p..Dose it really have to go back to Harris...?
Forts
Ontario, Canada
Depends what you do I guess. I've done a lot of bad things to Harris radios and never had to send one back.
That being said... Loading the wrong firmware to the newer 64bit M7300s... That's fatal.
radiotech33
County line road
yep I loaded wrong firmware ..lol..now its dead..so what dose harris do to bring it back to life ...its not gonna be 950.00 from me its got to be a trick
sbk1982
I think you can wipe the ECP clean through command line? I've done it with OTP at least. It's been quite a while.
Forts
Ontario, Canada
If you can get in thru hypertherminal there is hope.
19200,8,N,1 I believe. Power it up while connected and see if you get any activity.
radiotech33
County line road
Maby I just got a messed up radio..But I have had no problem with the 7 radios I done today
I can Not believe That a harris radio can not communicate some kind of way...what would shut a radio down for a mistake in a firmware change and it cost 950 dollars to fix it...Doa on this 1 ..lol Thanks
I thought it blew f301 fuse ..its ok..otherwise I assume its dead
sbk1982
Try the keypress/power up trick to force it into burnapp on bootup? It's really been a few years since I last bricked an XG radio. I'm more fluent on how to hose up and recover a new XL radio these days.
