Harris P5400
Lauchy_t
Harris P5400, can you program it without using a cable? Without the software aswell?
what’s the best place to get those sorts of thing?
Lauchy_t
What program would you recommend for a harris radio? I know basic chirp doesn’t show anything for a harris option but do you have any recommendations?
merlin
DN32su
You will need a newer version of RPM and a programming cable. the cable is pricy but cheaper at RF guys.
RPM ver 22 supports the 5400 but that will be expensive if you can find it.
The limit to over air programming is the personality, not the firmware.
I use chirp but at present does not support any commercial radios at all.
Programmer doesn't support the P5400 but that can be had free with a good search.
73s
AESFTW
You are going to have to find RPM as well as a programming cable. As mentioned above, RFGuys sell cables. You will have to do some searching online for RPM or contact a Harris dealer. With enough effort, everything you need can be found online. Do know that programming is much different from what is done through CHIRP considering they are commercial/public safety radios.
K2NEC
NA
I believe New London Technologies also sells programming cables
