Harris XG-100p charger malfunction?
KJ4SKP
I think my charger may be dead. When I place the radio on the charger there is no indicator light visible (either red nor green). When I unplug the charger at the rear and plug back in the charger light comes on (green for a second then red for a second) then the light goes out. Is my charger dead?
PACNWDude
Charger cradle (cup the radio sits in) is probably good if the light comes on momentarily. The "wall wart" transformer is bad. I had this problem with several of these, and a new transformer solved the problem. I even bought some spares from Radio Shack before they closed many of their stores. They are off-white instead of black, but still work.
Thunderknight
Bletchley Park
Make sure all the contacts (tabs) in the back of the charger are looking okay, none are broken or depressed into the housing.
KJ4SKP
weird! I found another charging cable that fit the charger. I have a new battery that I used the new cord to charge with. The charging cycle was fine, charger worked normally. when the charging cycle on the new battery completed, the charger exhibited the same behavior as before I tried the new cord. I thought I got off easy when I found a new cord that fit and seemed to work fine while charging. Now not sure what to do. New charger?
Ravenfalls
Ebay occasionally has new / light used $50 range. Buy 2nd if possible in case this occurs again.
MTS2000des
5B2_BEE00 Czar
there are two revisions of the charger. Which one are you experiencing problems with?
BMDaug
I am licensed…
Central Colorado, USA
Hey speaking of charger part numbers… does anyone have a solid part to replace the power supply brick that comes with the stock Harris charger? I have the cradle, but need a power supply that A) fits the barrel connector on the back of the cradle and B) supplies 12vdc 3a with proper polarity (center pin positive I believe)… It doesn’t need to be a Harris part as long as it meets the power requirements and actually fits… the “fits” part is the part I’m worried about. I can get 12vdc 3a supplies anywhere!
-B
d_strong
Rochester, NY
The model number is saw36-12.0-3000 12 volt power supply. I picked up a charger on eBay from base surplus. the charger didn’t come with the adapter but I was able to locate one on eBay.
