Seanm214
Hello,
Does anybody know if the Harris XG-75 is capable of Front Panel Programming (FPP). I have multiple Harris XG-75 radios, two of them have full keypad and the other two have partial keypad. Is it possible to do FPP with the full keypad versions to program in a frequency? If so how do you do this? I’m also having problems with the battery but I’m not sure if it’s because of the charger. I have the Global Technology Systems (GTS) charger for the Harris XG-75 battery and whenever I charge it the radio still always has low battery so I’m guessing it’s either a problem with the battery or the charger? Also whenever the radio is turned on I get the ERR 0552. What does this mean? I received these radios a while ago from a friend who used to work for Harris and I’m not sure how to make them work if they do work. When I turn on the radio it gives the brief ERR=0552 but then it turns on and displays CH 01 for example under CNV DIG. It also displays the channels under CNV ALG, CNV G2 and CNV G1. When I go to CNV P25, EDACS LY, EDACS G1 and EDACS G2 it says INV SYS which I’m assuming means invalid system and that the radio will not support these options. I’m also not sure if this is a VHF, UHF or 700/800 radio. People have told me based on the size of the tiny antenna that it is 700/800 radio but I’m not sure. I’m really just trying to figure out if these radios can be functional for any kind of use. I will put a picture of the radios down below. If these radios don’t support FPP than I assume I would have to get programming software to get any kind of use into programming these radios. Based on this information, do you think that these radios are functional for any kind of use? Thanks, any information is helpful!
