Harris XL-200P Side Port?
AF1UD
Any idea what the little circle port is for on the side above the accessory port? I can't find anything that uses it or documentation.
Thanks!
BMDaug
I am licensed…
Central Colorado, USA
Thanks!
It should be for an antenna on the remote speaker mic. I haven’t seen a product that supports it in the wild… a lot of older radios from the macom days had the same port (like the P7100 for instance).
-B
X9009X
Burlington, NJ
Thanks!
It is definitely the RF Connector for TAC Microphone with antenna or the Enhanced Vehicular Charger antenna connector.
jblackst
Knoxville, TN
I've also been told that the same connection is used when performing the pressure test for UL certification. The antenna style connection is removed for the test and replaced when the test is complete without disturbing the cover of the radio.
KE8VMK
Speaking of the EVC... Does anyone have a PN? I am only able to find the catalog #...
