In the Scanner / Receiver Antennas Forum, I recently started a thread about putting together a portable "mobile-base" antenna. Encouraged by the replies, I am trying to do that, but am nervous about pulling the trigger on buying some of the components without assurance by someone, more knowledgeable than I am, that I am buying the right bits and pieces.
What I am trying to do is use a Austin Spectra Mobile Antenna on a Laird Technologies Mobile to Base Station Adapter Kit, using a coax with the correct connectors so that an adapter is not needed, with a BCD436HP.
There are several versions of the Laird Mobile to Base Station Adapter Kit. The MBC800-NGP has a frequency range of 0-2500 MHz and is for antennas without a ground plane. This sounds like the right one to me.
I am planning to use 20 or 25 feet of either LMR-400 or LMR-400UF. Though it is more expensive, the flexible cable sounds like it would be a lot friendlier for this application. Is that coax okay?
If I understand correctly, the Spectra antenna, with the NMO mount, will attach directly to the Mobile Base Station Adapter Kit, without any additional adapter or connector. The antenna end of the coax would require a male N connector to attach to the Mobile Base Station Adapter Kit. The scanner end of the coax would require a male SMA connector to attach to the BCD436HP. This is the most critical part, do I have it right?
On one vendor's website, I saw an indoor antenna that utilized an Antennacraft ST3, mounted on a PVC mast, supported by a three-foot roof mount. I am planning to use the same tripod roof mount, but a Channel Master galvanized steel antenna mast. Is the steel mast, as opposed to PVC, a problem?
Many of you undoubtedly know this stuff off the top of your head, but it is foreign to me. Any input you offer will be appreciated. Since I do not even pretend to know what I am doing here, I will paste links to all the bits and pieces mentioned in case you have any questions. Have I got it right? Am I overlooking anything?
I know this is a lot of questions, I am just hoping someone will find it a challenge, or think it fun, to figure out what is wrong with my plan. Thanks for any helpful input.
Related Links:
My post, "Is a portable "mobile-base" antenna a plausible solution?"
http://forums.radioreference.com/sc...e-antenna-plausible-solution.html#post2437358
Laird Technologies MBC800-NGP
http://www.theantennafarm.com/catalog/laird-technologies-mbc800-ngp-7529.html
LMR-400UF
http://www.theantennafarm.com/catal...uf-1472:064c0ca1bf185080a42de5ec7766a614.html
N Male Connector
http://www.theantennafarm.com/catal...nm-3399:8abb45033d9e10c2fba304e88a45a98b.html
SMA Male Connector
http://www.theantennafarm.com/catal...-x-3448:3520d5b1e842efa2235373475398dc06.html
BCD436HP
https://www.uniden.com/scanner/id-BCD436HP/BCD436HP_HomePatrol_Series_Scanner
Indoor Antenna with PVC mast and roof-mount tripod
Indoor ST3 Antenna W/Floor Tripod
5' TV Antenna Mast | Channel Master
Related Links:
LMR-400UF
N Male Connector
SMA Male Connector
BCD436HP
