Havelock-Belmont-Methuen township Fire and Rescue
mciupa
Canadian DB Admin
Moderator
I'm here a lot
So far, members have only submitted 153.800MHz. TAFL shows many more.
Check these out for activity and report back to us.
Jradioptbo
Peterborough, Ontario
150.155 HBM fire.
Stn 1 is Havelock. Stn 2 is Cordova
Havelock had a major fire at an apartment last night.
HBM fire and OPP 2OPS15 were active with many comms.
153.800 is a Mutual Aid frequency for the adjacent Marmora and lake
HBM = Havelock-Belmont-Methuen township.
Rick08
Hastings Ont Canada
150.155 HBM fire.
That’s great. Thank you
w3rwn
PL is 110.9
Sorry guys forgot to submit that.
HBM is dispatched by Peterborough.
The 150.155 frequency is the Peterborough County Emergency Services Repeater in Nephton/Blue Mountain.
159.450 is the Peterborough County Emergency Services Repeater repeater at Douro.
Douro would have better coverage in Havelock/south and HBM are licensed to use it.
The 153.8 simplex is the original Ptbo County fire channel, and might be used as fireground simplex, traffic control on MVCs etc.
Jradioptbo
HAVELOCK-BELMONT-METHUEN FIRE DEPT.
HAVELOCK, ON - MOBILES
TX: 152.255 MHz
RX: 150.155 MHz
Licence: 010545909-003
CoE: 16K0F3EF
CORP. OF COUNTY OF PETERBOROUGH EMERGENCY SERVICES
NEPHTON, ON - COUNTY B
TX: 150.155 MHz
RX: 152.255 MHz
Antenna Height: 30 m
Licence: 010447465-001
CoE: 16K0F3EJN
Straight from TAFL
I was listening to the comm's on that frequency right on my scanner as that major fire happened.
HBM Fire is assigned to those frequencies.
Nephton is in Havelock-Belmont-Methuen township which also uses the same assignment.
Yes, HBM is liscensed to use Douro, as all other fire depts adjacent townships have each other's frequency for mutual aid. All dispatched from Peterborough Fire Control Dispatch in Peterborough on Sherbrooke St.
Also Asphodel-Norwood Township is in the midst of switching to digital, if not already. Once confirmed, I will submit that info.
w3rwn
TX: 152.255 MHz
RX: 150.155 MHz
CoE: 16K0F3EF
TX: 150.155 MHz
RX: 152.255 MHz
CoE: 16K0F3EJN
Straight from TAFL
Asphodel uses a VHF repeater on the water tank in Norwood. 152.810
You can read what they are doing here
It will look like the Selwyn Fire system with Fire on Slot 1, Roads on slot 2, and a dispatch TG for each fire station for Unication pagers, and a tac channel for comms. Bearcom has limited creativity :)
randyf
Strange days indeed
campbellford ontario canada
Asphodel Norwood running a medical call using frequency 159.4500
