Hcso - 851.5625
N4CYA
GA!
Anyone else hearing this alert type sound? This has been going on for the past couple of days...You'll hear it for 2 to 5 minutes then it'll end then come back on the air/frequency for 2 to 5 minutes...Is something going on or are they doing a emergency type test for this frequency?
- Jamie
N4CYA
GA!
Not sure when I am in Tampa I can hear this channel/frequency also all over in Brandon. Hillsborough county.
tampabaynews
Tampa, FL
Can you be more descriptive about the sound?
Anyway, that freq is assigned to the Hillsborough TRS.
