HDMI Cables
Point Nemo.
#3
I've always had good luck with Monoprice. Never had an issue with them and while you may find something a bit cheaper, Monoprice has been around for a while and seem to stand behind what they sell.
#5
I'll second (or third) Monoprice. I buy a number of different cables from them for work and personal use. They're much, much cheaper that you'll find almost anywhere else and I've only had a few minor problems out of the hundreds of cables I've ordered.
