Heads up Evansville
milf
Careful, I CAN hear you!
Indianapolis, IN
#1
MotoTRBO DMR TRS.... Most likely a Capacity Plus. It is an ERS project.
YW WRCA380
INDIANA, STATE OF
[Applicant is engaged in the operations of a hospital. Radios will be used to coordinate daily activities.]
Control Point 1 - 3400 Lincoln Ave., Evansville IN 812-469-6800
(link)
08/08/2018 License Issued
1 - 3400 Lincoln Ave., Evansville (VANDERBURGH) IN [Structure: Lattice tower] (map)
[Antenna 1 - HTT: 36.0m, HAAT: 35.1m]
453.325 FB8 Ant: 1 100p 70e Units: 1 11K2F3E 7K60FXE (DMR)
453.575 FB8 Ant: 1 100p 70e Units: 1 11K2F3E 7K60FXE (DMR)
453.7375 FB8 Ant: 1 100p 70e Units: 1 11K2F3E 7K60FXE (DMR)
2 - 32.0 km radius around fixed location 1
453.325 MO8 Ant: 1 40p 40e Units: 200 11K2F3E 7K60FXE (DMR)
458.325 MO8 Ant: 1 40p 40e Units: 200 11K2F3E 7K60FXE (DMR)
453.575 MO8 Ant: 1 40p 40e Units: 200 11K2F3E 7K60FXE (DMR)
458.575 MO8 Ant: 1 40p 40e Units: 200 11K2F3E 7K60FXE (DMR)
453.7375 MO8 Ant: 1 40p 40e Units: 200 11K2F3E 7K60FXE (DMR)
458.7375 MO8 Ant: 1 40p 40e Units: 200 11K2F3E 7K60FXE (DMR)
