Headset wire colors in pinout
Washington NC
#1
PMLN5278 wire pinout I need to make an adapter to make a headset with an M3 connector work on a different radio. I was hoping to find color codes for pinout so I can make an adapter using and old HT1000 housing to connect headset too.Going to use headset on a mobile that has no direct connection for a headset. Any info would be great Thank you
