Scannerfreak6743
First time I ever heard anything on this particular frequency (311.000 MHz). Thought it was cool and figured I'd share. The chatter was too faint to hear what was being said though.
EAM? What does that stand for?
No need for rude sarcasm. Could stand for many things. Learn to be more polite![]()
What Is An Eam
For those who think it's easier to annoy you than to Google 'What is an eam' themselves.letmegooglethat.com
No Sarcasm, direct and effective showing that a quick google resulted in the answerNo need for rude sarcasm. Could stand for many things. Learn to be more polite
And as I am sure you know but others may not, the transmission on both frequencies is usually simultaneous. Not these frequencies are also use at some bases. (323.8 replaced 321.0 for these some years ago.)That's one of the EAM frequencies! The other one is 323.800 MHz
Nevermind, I see you said "last night". There was an E-6 working off the coast for almost 8 hours that night between around 7pm to 2am, maybe that is what you heard ?Did you hear this around 11:35-11:40 by any chance ?
The message transmitted by them often occurs right after departure.Nevermind, I see you said "last night". There was an E-6 working off the coast for almost 8 hours that night between around 7pm to 2am, maybe that is what you heard ?
I've only heard them on HF. Are you talking about when they log onto the net right after departure ? I've heard that on HF often.The message transmitted by them often occurs right after departure.
No, talking about EAM...I suspect it is an EAM that announces they (as a command structure change) are airborne. They remote base at times out of Patuxent R. for the Atlantic.I've only heard them on HF. Are you talking about when they log onto the net right after departure ? I've heard that on HF often.
They also happen on FSK RTTY (along with MSK) from TACAMO on VLF (the primary TACAMO mission).I've only heard them on HF. Are you talking about when they log onto the net right after departure ? I've heard that on HF often.
