hearing lost
DX949
Banned
I have decided to install my scanner antenna in my attic, ( I have no choice )
what will be the lost in percentage of hearing capability if any to my scanner with a indoor scanner antenna
Thank you.
k8mcn
Old Monroe,MO
lots of variables
Are you presently using an outside antenna> or just a duck on the scanner?
How near or far are the things you want to listen to?
kh6idf
Houston, TX
I'm getting pretty good results with a Comet GP-1 2m/70cm antenna in my attic. It doesn't seem to hurt the reception/transmission that much compared to being outdoors. One thing that helps is I'm using low-loss coax (Browning BR-400A) and have only about a 25-30 foot length.
DX949
Banned
k8mcn said:
lots of variables
I have a base scanner (BCD996T) and I am presently using my 2 meter 70 cm antenna
which is on my roof as a scanner antenna,I am scanning stuff from about 138 miles round.
DX949
Banned
thank you for your reply and tips
k8mcn
Old Monroe,MO
Stick it up in your attic temporally and see what happens--pretty cool that you are getting over 130 miles coverage with it outside--i cant do that well with a scantenna and lmr 400 @ 25 feet
kibbins
It can also depend on what type of roofing & insulation you have too (i.e. metal or foil). My antenna works better outside but it was an improvement over the stock antenna when I put it in the attic.
