Toddbert
Is this possible? I'm not getting anything, and am wondering if I have misprogrammed the scanner, or if I just can't get the signal from here.
Toddbert said:Is this possible? I'm not getting anything, and am wondering if I have misprogrammed the scanner, or if I just can't get the signal from here.
Yes. I hear oodles of non trunked stuff, some of it quite a bit more distant.ScannerDude244 said:Is it the Santa Clara city 800mhz trunking system?
I'm Not hearing anything on the trunked system-- I'm guessing it's a programming issue; while I am actually good at programming the scanner, I'm not very good at 'reading' frequency charts to know what to program (for example, I set up the San Mateo trunked system wrong three times, but not because I couldn't program the scanner-- but because I didn't know it was "UHF").trooperdude said:Santa Clara has two VHF fire patches from their 800 trunked system so the
volunteers can hear what's going on via their legacy VHF pagers.
Are you hearing the VHF patch, or you are hearing the actual 800mhz
trunked system ?
Several channels on their 800 system are high-level, so it's not a problem
to hear them from Palo Alto.
If you are not, you are having either programming problems, or an antenna issue.
Toddbert said:In this case (city of Santa Clara), I have set up the scanner as '800Mhz standard', motorola, and put in what I think are the data channels-- 867.33750* 867.86250* 868.62500* 868.88750* (since it's a Uniden, that should be sufficent).
Toddbert said:Thanks, ingio8-- I tried what you suggested, and I can't pick up the signal from here. That;s fine, as I can hear plenty of other stuff.
Thanks to everyone who chimed in.
trooperdude said:Are you using the duck antenna, or an external roof-top antenna ?
Inside or outside ?
I can get Santa Clara just fine on my Pro96 with the RS 800 duck in
Palo Alto.
