Heliax NMO
WRCM
I saw a pic somewhere of a mobile feedline assembly of what appears to be 1/4" Heliax; NMO on one end and N male on the other. Anyone know where I can find something like that?
n0nhp
Grand Junction
That would probably be custom made.
The slight difference in power transfer between the TFE coax used for 800 MHz up and 1/4 heliax in the short run of a mobile install is going to be pretty negligible. Most customers and shops are not going to pay for the extra amount of time it would take to try to run and terminate the heliax or for the connectors.
I have never seen it advertised in any catalogs anyhow.
Good luck
Bruce
I've never seen one. Even the FSJ1-50 is kind of stiff for mobile use.
If you really need that, you can get NMO mounts that have N connectors on the base. You can then attach your own cable.
WRCM
Thanks; that's a good idea.
The one I saw was a complete antenna kit that was being sold with a 900 MHz radio. It is an Antenna Specialists RSPG1860T, if I'm reading the package correctly. But I'm not having any luck finding one to use with my TK-981.
I'll look for what you describe. I think that will solve my problem.
If you are just looking for an NMO mount that will work with your 900MHz radio, and if this is a "normal" mobile install, you shouldn't have any issues using the standard NMO mounts with the LMR-195, LMR-200, or even the dual shield RG-58. I've even seen a few running RG-400. I'm using standard NMO mounts with dual shield RG-58 at work on our mobiles, no issues. If your system is designed right and you use a good antenna, the slight additional loss in the coaxial cable won't be an issue.
WRCM
Thanks. Yeah, with 10 feet of feedline almost anything will work. I just saw that antenna kit and figured that would be ideal if I could find one. If not, no biggie.
