Help GP 340 doing my head in
bigtj
Hi all I have a gp 340 on vhf high band it works fine until 20 minutes of no use it emits the 300hz tone as you get when you power it up Firstly I thought the batterries were u/s but having tried a new battery from a friends it done the same thing When I transmit the radio then emits the battery low tone I have no idea what is wrong with it anybody advise me I have diagrams and software. This one has done my head in Should i make a nice paper wieght from it ??
trlrdrdave
decatur, al
Make sure the battery contacts are clean on the radio and inside where they contact the frame. Also could be the volume pot/ off on switch.
