CorwinScansNM
I am confused & wondering what in the heck kind of connection this is considered to be on the NMO Base of the Browning BR-137? Please see my images.
I took the screw-on part of the Browning BR-137 NMO antenna off as for I just purchased & own one of the JETSTREAM JT776SMA Antennas that I wanted to & had plans of screwing on & installing on the heavy duty Browning BR-137 NMO Antenna Base to then put on my NMO ground plane kit that is installed on my antenna mast outside. The turnout was not what I expected it to be & did not go smoothly as planned. The Female connection on the NMO base of the Browning BR-137 is a tiny bit bigger/wider than a normal SMA Female connector & has a hole for a medium sized connection/contact pin. Therefore, I am now stuck & trying to figure out what type of connection adapter I need if it even exists to be able to install my new JETSTREAM JT776SMA Antenna which has a Male SMA connector with a center pin in it (onto the Browning BR-137 NMO Base)?
Any clues, ideas or suggestions on what type of Female connection is on the Browning BR-137 NMO Base? I certainly do not know & am currently at a standstill which is why I decided to post the images & question here on RadioReference.
