Help identifying connector and wiring diagram
Samg381
I am trying to identify this connector. Based on my research, I believe it is a Kenwood K2.
If so, could someone kindly provide me with the relevant wiring diagram / pinout?
Thank you very much.
littona
Super Freq
Council Bluffs, IA
Flip the picture upside-down where the screw is on the bottom. Pin numbers start at bottom left and go up, left-right, left-right, etc. 1-14.
1- GND
2- RXB
3- RXA
4- GND
5- TXA
6-
7- PTT
8-
9-
10- GND
11-
12-
13-
14-
Regarding the other leg of the TX audio... for interfacing with the Raytheon/JPS ARA-1/NXU-2A/ACU1000/etc., TXA and TXB are put across a 22 ohm resistor. TXB is tied to ground and one leg of the resistor. The other leg is tied to the TXA pin. This allows them to use the unbalanced audio from the MIC.
Got this info from Raytheon/JPS interface cable 5961-281013-00, which is used on the TK-280/290/380/480/2180/3180 portables.
  • Kenwood TK-290 Rev A1.pdf
Samg381
Thank you both very much! You guys just saved the day.. Using the info you generously provided, I put this simple diagram together.
This connector is attached to an OTTO PTT headset that I'd like to use with my Thales Liberty radio.
Assuming my diagram is correct, my plan is to disconnect this adapter and splice it to a 6-pin hirose cable I've attached to a Thales sidemate hirose/programming adapter.
My only two unknowns now are:
- which wires pass through the Thales adapter to the hirose connection (I plan to use a multimeter here)
- which wires I need to splice from the headset cable to the hirose cable
Here are photos of my setup, and the pinout to the Thales adapter:
Any guidance here would be greatly appreciated.
Samg381
Any guesses what the odd pin out is on the Kenwood connector? Since there are 6 wires in the hirose cable, could it be that both grounds share a common wire?
