[Help] Kiwisdr & FLDigi setup. Windows 10
K5KNT
Ogden, Utah
Before I invest in a radio I want to see if the digital modes are something I would be interested in. I've decided to try and monitor some of the PSK31 traffic using the various kiwisdr online radios and FLDigi. I've downloaded VB-Audio cables and installed them to link the sdr and FLDigi.
The FLDigi audio setup has the capture device as "CABLE Output (VB-Audio Virtual Cable)"
and the Playback as "CABLE Input (VB-Audio Virtual Cable)".
If I select "Speakers" or "Headphone" from the taskbar I can hear the audio from the SDR but there is no activity on the waterfall in FLDigi. If I select "CABLE Input (VB-Audio Virtual Cable)" from the taskbar the FLDigi waterfall begins and I can decode, but I can't hear anything.
Is this normal or is there some way to pipe the audio signal to FLDigi and be able to hear it at the same time?
Thanks,
Kent, K5KNT
K5KNT
Ogden, Utah
Disregard, I discovered that the checkbox for "Listen to this device" was unchecked in the CABLE Output properties.
