prcguy
I would not expect 900ma anywhere in the keying circuit. You could put the multimeter in current mode and put one lead at ground and the other on the mic pin that keys the radio. That will key the radio and tell you how much current is drawn through the mic PTT switch. Probing the same points with the multimeter in the DC volt mode will tell you if the mic PTT is pulling the key line all the way to ground or not. It may not if you measured 4 volts but any aftermarket mic will be a direct short from ground to the key line when you push the mic button.
Those are the readings I got when I would key the microphone on the uniden 510xl. I used my multimeter on the ground and the transmit terminals on the ptt switch.
