I have yet to see a ham radio with a faceplate like that, and with a couple of exceptions, ham frequencies are not channelized.
Not sure what you mean by you "have yet to see a ham radio with a faceplate like that", do you mean the blue faceplate or do you mean a faceplate laid out in that general format, like a CB? I have seen several ham radios laid out like that. You can say what you want about them being thinly disguised Export CBs or not, but many of them come from the factory working on the ham 12 and 10 meter band and called, by the maker, "ham" radios.
If they cover ham frequencies, and they are sold as ham radios, that makes them, by definition, ham radios. And quite often very usable as such.
As for ham frequencies not being channelized, it may be true that there is no assigned channelization on ham frequencies, but that does not mean you can't use a radio that is channelized, as long as the channels fall on legal ham freqs. And outside the world of Export CBs being applied to ham radio, there have been other (several) radios in the past with a channel selector. It is a practice that is not often found today, but was used in the past, mostly before PLLs and synthesized frequency generation. You might look at things like the KLM Echo 70, a 70 cm weak signal (SSB) radio, the KLM Echo II, a weak signal 2 meter radio, or some of the early 2 meter FM gear. Some of this gear used the same 23 (or 24 / 25) channel selectors and channel knobs as would be found on CBs of the day, since the parts were readily available and low cost.
Not to mention I have used several CB "regular" radios converted to work on 10 and 6 meters. That is one of the benefits of ham radio, since we generally do not need type certification or acceptance for our transmitters we can repurpose radios as desired. I have often run repurposed military gear and maritime gear, both of which are quite often channelized, on ham bands.
T!
