Help needed !
FrankM
Sioux Falls, SD
I have a new BCD996P2 that I need to program and I have the programming PROSCAN. However I just need some help in understanding how to use this program. Anyone in the Sioux Falls area or nearby that maybe I could get together with to help me. Thank you
Whiskey3JMC
Just another lowly hobbyist
Philly burbs 🇺🇸
ProScan
Software Provider
Ontario, Calif.
What exactly are you trying to do.
Did you see the Quick Steps in the manual?
1st thing you want to do is select the scanner type then get the serial port comms working?
If you're trying to upload or download from the database then you want to create a new database 1st. Go to the Database menu then click on new then select a location and type in a filename then click the Save button.
