Depending on how much effort your willing to put in, you can get a programmable UHF radio that covers 462mhz (commercial or ham) and program that for your channel. Personally i use used Motorola CDM1550s and MCS2000s, but their still a few bucks. There's cheaper companies like Retevis that makes pretty cheap but fairly nice equipment including mobile radios that can easily be programmed for GMRS (as well as anything else). If you go this route, for the love of [insert deity] make sure you do not key up on the wrong frequency (which it would tell you on the screen or when programming).
Just keep in mind if you do get a mobile style radio, you also need the mic, power cable, antenna, and you need to make sure your antenna has the proper connection (or get an adapter). You can get a cheap magnetic antenna or get an NMO antenna and mount if you want to do something a little more permanent.
I'm still in the process of setting up a fairly advanced GMRS system for my family and friends, but I have looked around at quite a few radios and their features, as well as used allot of programming software at this point. If you need help with anything feel free to ask.
