I hadn't thought about alert tones. That would be another method to differentiate them. With most of the software programs, you can select multiple channels and change all of them at the same time. You could also set the alert LEDs (if the scanners have that option), but in a bedroom, at night, that would be distracting for some users.Can you set alert tones for the different scanners? I know on both of my digital scanners, I can set an alert tone when squelch is broke.
Maybe have the same alert tone for one scanner and a different alert tone for the other?
Of course, this would mean setting the same alert tone on one scanner for all frequencies you have programmed into that scanner and you'll have to do the same for the other scanner.
A lot of work manually but software makes it much easier.
I have two port ale scanners set for two separate counties on my nightstand
The problem is I have a difficult time distinguishing the different calls and understanding both equally. Any help is appreciated.
It can be done. You learn to react to certain things while others go unnoticed. In our mobile command post, we have a variety of radios (800 mHz, air, marine, UHF, VHF, ham, etc. Over the years, I have learned to pick up on certain words or, maybe, elevated voices, etc., to draw my attention. Now that I'm about to give up as communications officer on the "bus," I've gotten pretty good at it.Listening to two or more scanners is an acquired skill that is gained through listening to them. Be patient with yourself.
Jim41
Jim41
This is what I also do. Don't have the scanners' speakers next to each other. Organize your scanner programming so that scanners have a "priority". Set the volume the highest on the scanner with the highest priority, etc. I have one scanner programmed with stuff that is "local" to me and it gets the highest priority. Any scanners covering "the next county" get a lower priority.Or, using external speakers if necessary, separate either the two scanners, or the external speakers, enough to that one is louder in one ear, with the second one loudest in your other ear.
I have five scanners, with multiple agencies programmed, running in my bedroom. Over time, you get to where you can 'tune out' what is not of interest, and certain words, or rapid calls & replies, get your attention if something interesting is happening.
No kidding. Back in the dark ages when I was still an RDS I worked Dispatch fairly often and had no trouble juggling multiple radios, the phones, the interphone, and people walking up to the window because dealing with walk-ins was the Dispatcher's job once the front office closed. Unfortunately, my ears aren't as young as they were then...I have trouble with multiple radios going at the same time. Separating them does help, as inconvenient as that can be.Get a job as a 9-1-1 dispatcher. You'll learn.
