Help programming scanner
davidtaylor30
Davie, Fl.
I have no idea why my scanner does not download the new information from this site. I must say I thought I did everything correct but as of now I have no clue of how to update the re-banded channels for Broward County Fl. I guess I need step by step instructions. Completely lost. Uniden 396t
W8RMH
Feed Provider Since 2012
The BCD396T will not download information from this site.
You will need a software such as FreeSCAN to download the information.
You will then use the FreeSCAN to upload the information to your scanner.
If you inquire in the Florida Forum someone in your area may know the rebanding procedure, which may just be a simple frequency change, which could be done on the radio keypad.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
In addition, you need the latest firmware for your 396T. Out of the box, the firmware won't support rebanding.
Unfortunately the process of updating the firmware is something of a royal pain. Go to the Uniden TWiki (link below; links are always blue) and follow the instructions precisely. Don't skip anything...
BCD396TFirmwareUpdate < UnidenMan4 < TWiki
and from our own Wiki, some common Q&A about the firmware update process
Updating the Firmware in Uniden DMA Scanners - The RadioReference Wiki
HTH...Mike
