Help Programming TK-2360
huntercody
Corvallis, OR
#1
Here is the issue: I can not get KPG128D software to write/read a TK-2360-K. I have done quite a bit of programing in the past. I just programmed three of the same radio type. But for some reason, I can not get this one radio to work. It is not a com port issue, as I have looked into that. Any suggestions. Thank you
