help rebanding in forsyth co.
edc1056
Clemmons NC
Tryed to reband my bc346xt . not sure i did it right but i tried. What all can i here if i get it to work? Scanner is not digital so will rebanding help me? Would like to get forsyth county and winston pd. I think they are digital but i read that rebanding would work for kernsville and forsyth co. Thanks if anyone can help.
fcfd988
North Carolina Foothills
You will need a digital scanner to monitor the Winston-Salem/Forsyth County System. You will also need digital to monitor the Kernersville System.
Simply updating the data in the scanner by adding the re-banding data will not work because your scanner is analog only.
Wes
