Help using Spectra for streaming online
Asmitty0010
New Hampshire
I want to use a left over Spectra that i'm not using for my online feed i currently provide on Scanamerica.us and over at Scannewengland. I'm using a scanner for the feed now but I want to use that mobile I have laying around because the RX and audio are day and night. However when I RX audio it seems to trip something in my computer and causes the sound card to stop working. I then unplug it and plug it back in and it works for a second and then same thing. This doesn't happen with audio comes from the scanner.
I had a radio tech tell me there may be some DC voltage coming from the radios speaker feed and that I need to add an audio transformer. Can anybody elaborate on this?
Thanks!
WayneH
Forums Veteran
Super Moderator
Your master site
I forget the technical details for why but you do NOT want to directly wire anything but a standard Motorola speaker to the Spectras speaker output. Anything else must be isolated with an audio transformer.
Be thankful it didn't blow out the audio amp. It's a common problem.
zz0468
Banned
Look on batlabs.com, and the bat board.
There's low level audio available on the accessory connector, but it's not squelched. Speaker audio is at least squelched, but you have to deal with the fact that the audio amp is dc coupled to the speaker. Like Wayne said, treat it badly and it WILL fail.
Someone on the bat board had come up with a circuit that would take speaker output, isolate it, and derive a COR output, all without modifying the radio. There's schematics, board layouts, and parts lists. Personally, that's not how I would approach the problem.
The better solution is to use the low level audio at the accessory connector, and modify the radio to bring out a COR signal, and squelch the audio externally. It's more work, but then you don't have the volume control messing with your streaming audio levels.
