Help!!!!! Very frustrted.
jimmnn
Colorado
Finally have a pro 106. Cant manually program it and the software is aggravating. Any Help?
Take a deep breath are you using Win96? It's great and easy once you understand it, have you tried the tutorial?
If still frustrated contact Eric at the RS store on the 16th Street Mall and I'm sure he'd be happy to set you up correctly.
Jim<
abqscan
DataBase Administrator
Moderator
AOA
I work tomorrow from 11-5 if you would like to stop by.
batrastard
Northglenn Colorado
Wirelessly posted (BlackBerry8310/4.5.0.124 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/179 UP.Link/6.3.1.20.06.3.1.20.0)
What value needs to be in the wildcard area for a value? I am using win500.
T-Santon
Ohio's Snow Belt
Just type the word 'Wildcard' in the "Group or Radio I.D." column....Then, set the "Type" to Group (if you want to hear talkgroup wildcards) or Private (if you want to hear I-CALLS).
Most people use two Wildcards for each system (one set to Group, and one set to Private).
batrastard
Northglenn Colorado
So leave the wildcard alone and change the group or private settings?
dougw65
Keep watching this forum.. I've been working on a new file that I will post to this forum---probably by tonight or tomorrow. I'm in FC but I have adams county in the file and I see no reason why it wouldn't work for you.
Also, check the software section for win 500 info. There's a great wiki type tutorial that makes win 500 much more enjoyable to use!
batrastard
Northglenn Colorado
Thank you all for you're help. After walking away for a bit I was able to figure out my problem. It I great to hear what I have been missing since being here.
