Help w EVX-S24
pdoug3rd
Hey! So our school has the Motorola EVX-S24 and we recently purchased the SAMCOM FPCN30A. Even after changing the channels to the same channel and programming the same frequency, the two radios still can't communicate. They both show they're receiving a transmission, but we can't hear anything on either radio. I'm new at this, so can someone help me with what I still need to do?
nokones
Sun City West, AZ
The SAMCOM FPCN30A is only an analog radio and the operating band range is 400-480 Megs. The EVX-S24 radio also will operate 403-470 Megs and will operate with either analog or DMR emissions. You'll need to set up your EVX-S24 channels for analog operation in order to communicate with the SAMCOM FPCN30A radios.
Make sure that both the EVX-S24 radios and the SAMCOM FPCN30A radios are transmitting and receiving the same freqs and tones/DCS codes on the respective channels.
pdoug3rd
So I have the analog setup and they're all the same frequency. I guess the tones/DCS codes is what I need to work on. Any ideas on how to do that?
Also, Thank you all for the help!!
FKimble
Newnan, GA
Just delete all the tones. If you still can't transmit and receive between the two brands. then you can eliminate tones as a problem. Once you get the radios talking then you can go back and put in tones if you think you really need them.
Frank
pdoug3rd
Take them to whoever is in charge of your radios and see if they can help you.
Unfortunately as the Asst Principal, that role has fallen to me (except I don’t have a clue what I’m doing). Our tech guy is out of town, so I’m hoping once he gets back that he might know something or know someone.
pdoug3rd
Frank
Thank you! I will find some YouTube videos and try to do that!
