Help With 996 Display
So. Middle TN
#1
As my 996 is scanning, the display shows "Qck Save Cnv Sys" and it alternates between displaying this message and showing the systems I am sacnning. It sometimes stops on a NOAA weather radio frequency and then continues on. I have checked the weather settings and priority, but I have been unable to get this to stop. Can anyone help?
Indiana
#2
You have saved the weather channel in the quick save system that you have also generated. Go into : Menu - Program System - scoll down to the quick save system and delete that system.
