I have 4 scanners that I'd like to hook up to the antenna, is this possible, if so how would I go about doing this?
Start out here (-->
http://forums.radioreference.com/sp...5054-using-one-antenna-multiple-scanners.html <--) and most of your questions should be answered.
I've seen others tie transformers and amps into the connection between the scanner and antenna, what are the reasons for doing this, can I go without these and just mount the antenna?
The antenna is designed to be used with that old 300 ohm twinlead feedline (think of the TV antenna feedline used prior to Cable-TV). To convert it to something more useful, you'll need that 300 to 75 ohm balun (looks like a transformer). This should've been included with the antenna, but if not, they're easy to find at your local Radio Shack (get the one designed for outdoor mounting (
http://www.radioshack.com/product/?productId=2062049) or you'll have moisture issues!!!). You can then use some standard RG-6 coax to move from your antenna to your scanner.
An amp is good if you have weak signals (and none that are real strong, even out-of-band like FM or TV broadcast stations with nearby towers) and you're in a rural area. If you're in the city or locations where there are strong signals an amp can make things worse. Basically (and least expensively) you can set things up without an amp and add one later quite easily if you find you really need one.
Any suggestions on mounting the antenna?
Get a 10' (or better) metal pole and mount it where you can do so securely. Mount the antenna to the top and route the cable safely into your scanner location (yes, it's that simple!).
Now the hard part, grounding. Drive one or more ground rods near the antenna mount location to ground it. Attach a ground wire (#6 or larger - physically larger, with smaller wire gauge numbers) to the mounting pole. Where it enters your house, place more ground rods and attach them to a ground block (like -->
http://www.radioshack.com/product/index.jsp?productId=2150597).
Note that this grounding information has been simplified to cover the absolute minimum basics. Search the forums here for better and more complete descriptions on what you should do.
