Do you have an ohmmeter?
If so, check for continuity between the center pins of each connector and the outer ring of each connector. There should be very low resistance. Then make sure there is no short circuit between the outer ring and inner pin.
If that's all OK, then check the antenna... (What are you using for an antenna and scanner)?
