Help with firmware updater
#1
I downloaded the firmware updater and installed it. When I run it this is the error I get Internet access failed the remote server returned an error:227 entering passive mode (69,15,51,147,7.17). I had no problem with the last firmware update,
#3
Is there another way to get this file? I have never had this trouble before. Have updated firmware since updates became available with older radios.
