Help With HT1000
lls207
Los Angeles, California
7/6/16
8:26am PST
I've been away from computers and radio programming for awhile. Open heart surgery.
I have the HT1000, rib and programming cables and programming. I forgot how to run the program.
I have a old laptop with Vista on it. I have programmed the MTS2000 and HT1000 on it.
I know where the "Comand Prompt" is. I don't know the next step.
I have the MTS2000 programming software on a disk from Motorola. All that I remember. I'm just stuck where to run the file from and how to get DOS to read it.
Thanks,
Took me a few days to ask for help...seems stupid. Hope my memory gets back to where it was.
LLS207
Los Angeles.
601
Fayetteville NC
If I recall correctly, you just have to enter HT1000 after the command prompt of the drive letter your floppy is. That's it. You could also do ht1000.exe
Make sure you run the ht1000 in a pure dos environment. If not it may fail to read or write the radio or not do it at all.
lls207
My problem is I do or know where to actually store the file so it can be read by dos.
I put the program in a folder on my desktop. If I just put "HT1000" after the prompt it does not understand what I want it to do.
I think I need to name the folder, and.put it somewhere, and then type? after the prompt.
Thanks.
LLS207
mikewazowski
Staff member
Forums Manager
Oot and Aboot
MTS2000 software will not program an HT1000.
You'll need to find where the HT1000 software is installed in your computer. Try looking under c:/rss/ht1000 or possibly c:/mrss/ht1000.
Once you find the correct directory, you just type ht1000.
lls207
I do have software for both radio. Also own both radios. I haven't programmed these radios in over 16 years. I only need help getting the HT program to run in dos.
Forget the mts2000 I remember all about programming the radio.
Just tell me what to call the folder where I keep the program. Where to put the folder and what I type in dos to start the program.
Name the folder whatever you want. Then put all the ht1000 files in it. In your windows explorer right click the ht1000 exe file and look at its path. Copy it down then type it in the dos command. Maybe try cd\ c:/rss/ht1000 then once in the directory it is in type ht1000.exe press enter as mentioned above.
cmdrwill
So Cali
See just how much DOS we have forgotten over the years.
Most RSS, radio service software, was installed in the MRSS directory. Each in it's own separate sub directory of MRSS.
