Help with LCN input
gopherit
Toronto Ontario
I'm trying to programme EDAC Halton, London and Ottawa. I get as far as the LCN input. don't know what that is and where I find it. Can anyone help with that ?
Larry
EJB
Downtown Hamilton
Larry
It means that for these systems enter in ALL the frequencies in the order that you see on the database, otherwise it will not work.
UPMan
Uniden Representative
Arlington, TX
The LCN is the little two-digit number next to each frequency.
gopherit
Toronto Ontario
Thank you Guys.
Now I have a much better understanding of the EDAC system. you saved me a lot of frustration, time & error...
I like to programme them manually. It helps me understand how they work much better.
Larry
Forts
Ontario, Canada
The London EDACS system is in the process of being converted to a digital P25 system.... So you will be able to cross that one off your list before too long.
