Help with Motorola RLN4883B 12v vehicle charger hard wire install
GBLOCK
The Sunshine State
Looking for assistance on how to hard wire a Motorola RLN4883 travel charger that has its cigarette lighter power plug cut off. The coil power wire coming out of the charger has 4 small wires inside of it (red yellow white and black).
What do each of those wires stand for and which wires do I connect to the + and - power source inside my veh?
Well Known Member
SNCZCA01DS0
Those have some electronics in the plug, and I'm not sure you can cut it off and just supply 12v hard wired. Might be better to just install a lighter plug in a hidden location and keep it plugged in.
TDN9816 would be a better choice if you are using a Jedi model radio, but they are ugly as sin. I keep a RLN4883b in my truck for charing my HT1000, though.
rjk_165
Those cigarette lighter plugs usually have a fuse and holder assembly built into them.
Some other minor circuitry too, I think, like the LED light that shows it's plugged in.
