Help with Motorola system saber
brian0007
new york long island
I just got 2 sabers from my cousin in tx . one is a systems saber model 3 and the other is just a saber model 3 . i got the rss for both of them and im trying to run them through dosbox but i cant get either of the radios to read . im stumped . im more familliar with cps for my xts3000 . what can i do or am i just stuck . ive got a rib and have a cable . any advice would be greatly appreciated
yaknamedjak
localhost
The RSS can't access the serial port of the pic via Dosbox....gotta run it in DOS
teufler
ST PETERS, MISSOURI
possibly a shell to dos will work rather than finding an older dos machine. I have been sucessful when programing GTX, mts1000, and gm 300s.
RKG
Boston, MA
Important for Saber and Systems Saber that OS permit application to have direct access to the UART. Windows (including DOS shells under Windows) blocks this. Run RSS under native DOS.
jim202
New Orleans region
Your finding out What many before you have already discovered. Many of the older Motorola software programs do not like to be run on anything but an older computer that has a built in serial port. In many cases you computer speed needs to be under a clock speed of about 800 MHz or so or slower. It may also take a small DOS program like cacheoff.com to be run to shut off the computer cache.
This pure DOS operating system and the serial port are a staple requirement for many radios like the Syntor X9000, Spectra, the serial interface unit (SIU) that the Spectra can use, the Saber and several others.
If you don't have a computer that is slow and has a serial port, start stopping by the older computer repair stores and see if they just might have something laying around. In many cases they will just give them to you to get them out of the store.
You can hunt around on the Internet and find a number of places that you can download one of the many versions of DOS from. Just bear in mind that if you are going to store the programs on a hard drive, it needs to be an 80 GB or smaller hard drive. It has to be formatted as a FAT32 for DOS to be able to read it.
As a side note, I tend to use the 80 GB hard drives and load DOS onto it along with windows 98 or XP. You partition the drive for say 20 GB for Dos and load DOS into that partition and the rest is used for Windows. This way you can run the old Motorola software in DOS and have Windows to transfer files between computers using an IP network connection to the other computers. Windows will work just fine with the FAT32 formatted hard drive.
If you don't want to partition the hard drive, then just make a DOS boot disk and run it from the floppy drive. that way you can have Windows loaded and use DOS also. Just remember to put the DOS boot disk into the floppy drive before you boot up the computer. Plus you need to set the BIOS up to have the floppy drive be the first boot device. When you don't want DOS, just remove the floppy and the computer will boot up in Windows.
Another point to remember is that DOS can only have file names and directories with a max of 8 characters. Like a directory of syntorx9 will work, but syntorx9000 is too many characters. The same thing for file names. You can have spectrav.com but can't have spectravhf.com for a file name. Remember only 8 characters that can be any combination of letters and numbers.
brian0007
What baffles me is I can run the motorola m120 rss through vista's comand prompt but these 2 radios have me stumped. I'm using a rib through a serial port . I will not use USB . I've got to much invested in other radios to risk bricking them .
I have an multiple xts3000, m120 .
I'm surprised that someone hasn't made a newer style program that will run in the newer computers . I can use dos but it's been so long half of the dos prompts are forgotten .
Project25_MASTR
TX-COMU
Texas
You can get DOSBox to work but it takes 3 things. Windows (won't work in Linux or OSX), a real serial port (they hang if using an USB to RS-232), and some luck.
Being said, I use a P3 PC running FreeDOS for programming. It'll run with Spectra's with the cache off. It'll run the Syntor RSS and R100 RSS with the cache off but I haven't tried read or write. I've programmed Radius series on dual core under FreeDOS but that's with a real serial port.
MTS2000des
5B2_BEE00 Czar
Systems Sabers are 1990 era technology. If you aren't using a bona fide DOS environment that allows direct UART access, you're peeing up a rope and you can brick those in a flash.
When analog Sabers and System Sabers get bricked, they are not like newer radios that can be recovered.
Do yourself a favor and start with the right combination of hardware and operating system, then go from there.
