I'll add this as just a friendly suggestion:
I see your post count is 1 and you said you are "new to this radio stuff".
I run a number of radio systems, including some for fire and police departments. I'm suggesting this as a friendly request:
Please do not program in any transmit frequencies for any of these agencies you are wanting to listen to. While you may very well be disciplined enough to not transmit where you shouldn't, all too often the radio can fall into the wrong hands. A radio can be stolen, lost, or simply picked up by a child or unknowing friend. It's way too easy to press the push to talk button on a radio and not realize the issues it can be causing.
The NX-200 is a really solid radio and should give you years of use. I'd recommend putting it to its full potential by looking into getting your amateur radio license. This radio will work great on the 2 meter VHF band (144-148MHz). Getting your license will teach you a lot about radios, how they work and what you can do with them.
Good luck and enjoy your new radio.
